איום התאבדות - כללי - HWzone פורומים
  • צור חשבון
איום התאבדות
aquarius
Recommended Posts
אם מישהו לא מביא לי את הדבר הבא למגש אז אני קופץ מהגג שח עזריאלי בלי נדר
Cases (Computer Cases, ATX Form)
RAIDMAX Samurai Black ATX Mid tower Case With 450W PSU, Model "ATX-901WBP" -RETAIL
Item# N82E16811156173
Status: In Stock
Save to Buy Later
Remove Item
$132.50
$132.50
Fans, Heatsinks (Case, CPU, Chipset)
ZALMAN RESERATOR 1 Fanless Water Cooling System(Reservoir+Radiator+Water Pump) -RETAIL
Item# N82E16835118111
Status: In Stock
Save to Buy Later
Remove Item
$238.99
-$20.00
Instant Rebate
$238.99
-$20.00
Instant Rebate
**This item may only be returned for a replacement of the same make/model.
Masscool Hard Disk Cooler, 130 x 100 x 17 mm, Model "4B02S4"
Item# N82E16835150005
Status: In Stock
Save to Buy Later
Remove Item
$3.19
$6.38
Enermax Whispersys System Exhaust Blower (Slot fan), Model "WS-8SLFS"
Item# N82E16835888003
Status: In Stock
Save to Buy Later
Remove Item
$4.99
$4.99
Hard Drives
Fujitsu 147GB 15,000RPM Ultra SCSI320 80pin Hard Drive, Model MAU3147NC, OEM
Item# N82E16822116154
Status: In Stock
Save to Buy Later
Remove Item
$879.00
$879.00
Maxtor MaXLine III 300GB 7200RPM SATA Hard Drive, Model 7B300S0, OEM Drive Only
Item# N82E16822144363
Status: In Stock
Save to Buy Later
Remove Item
$209.00
$209.00
Memory (System Memory)
OCZ Performance Series Dual Channel Kit 240-Pin 2GB(1GB x 2) DDR2 PC2-5400, Model OCZ26672048PFDC-K -RETAIL
Item# N82E16820227011
Status: In Stock
Save to Buy Later
Remove Item
$533.00
$533.00
Monitors - LCD Flat Panel
SAMSUNG 915N-Black 19" LCD Monitor with 8ms Response Time -RETAIL
Item# N82E16824001185
Status: In Stock
Save to Buy Later
Remove Item
$409.00
$409.00
**This item is warranted through the product manufacturer only.
LG Electronics L1980U 19" LCD Monitor -RETAIL
Item# N82E16824005034
Status: In Stock
Save to Buy Later
Remove Item
$579.00
$579.00
Motherboards -
DFI "LANPARTY nF4 SLI-DR" NVIDIA nForce4 SLI Chipset Motherboard For Socket 939 CPU
Item# N82E16813136151
Status: In Stock
Save to Buy Later
Remove Item
$210.00
$210.00
Processors
64 FX-55, 1MB L2 Cache, 64-bit Socket 939 Processor - OEM
Item# N82E16819103492
Status: In Stock
Save to Buy Later
Remove Item
$815.00
$815.00
Sound Card
Labs Sound Blaster Audigy 4 Pro PCI Sound Card, Model "SB0380" -Retail
Item# N82E16829102181
Status: In Stock
Save to Buy Later
Remove Item
$286.00
$286.00
Speakers
Logitech Z-5500 5.1 Digital Speaker System w/Digital Hardware Decoder -RETAIL
Item# N82E16836121120
Status: In Stock
Save to Buy Later
Remove Item
$269.99
$269.99
Video Cards
Leadtek nVIDIA 6800 Ultra Video Card, 256MB GDDR3, 256-Bit, HDTV-Out/Dual DVI, PCI-E, Model "PX6800Ultra" -RETAIL
Item# N82E16814122214
Status: In Stock
Save to Buy Later
Remove Item
$519.00
$1,038.00
$5,590.85
קישור לתוכן
שתף באתרים אחרים
מה אכפת לכם תלכו להודו קחו מכל הודי שקל (תגידו שזה בשביל רווחת הפרות) אם אתם עושים את זה אתם מקבלים חצי
בהרבה מקומות בהודו 60שקל זה התשלום החודשי על עבודה...
קישור לתוכן
שתף באתרים אחרים
  • צור חדש...
